Driver Door Window Issue: Not the usual one
A great resource for wiring diagrams and a bunch of service manual technical data can be found here: https://schwarttzy.com/h3-hummer/#h3-hummer-manual
Maybe download a local copy in case it ever gets pulled off the web.
A great source for exploded parts diagram can be found here: https://webautocats.com/en-us/epc/hummer/
I use this whenever I'm looking for a part number for something.
This is a great resource for the meaning of Hummer specific codes: https://www.dtcdecode.com/HUMMER
Minor Update: So I pulled the driver door off of the vehicle entirely, checked the 'can bus' connector for the door harness, checked continuity on the door side, then voltage to the pins on the vehicle side, I checked under the dash, behind the kick panel, and along the door trim for any wires that were broken/frayed or anything like that. I pulled the switch panel out again and probed it, all voltages seemed good. Getting a better look at the pins on the large harness connector that goes between the door and the vehicle, there was one pin that had corrosion on it, almost looked like a fuzzy film of sorts. So I used contact cleaner and a fiberglass brush to clean it up as best I could, re-installed the door. The aftermarket switch box is still in place at the moment, but I wanted to try it, bam, window works again, faster than previously too! Maybe it was a combination of the non-OEM switches and the pin corrosion? I did end up biting the bullet and snagged a GM original switch panel and will be swapping it out as a precaution to all this happening -again-.
Once the GM OEM switch cluster is installed, I'll see how that works for a little while and hope/pray that it doesn't bugger up on me again!
So! Keeping my fingers, toes and eyes crossed (Unless driving of course) that everything thus far has been okay. Windows, locks and everything else are working now that I've replaced the aftermarket driver door switch cluster with the OEM GM one. Also I do think that the corrosion that was on the pin in the main door harness into the body could have been additional, thankfully after cleaning that off thoroughly, no more issues.
Hopefully, it remains that way! So just goes to show you, get what you pay for I guess! Lol.
Kknox
Nov 20, 2017 05:03 PM
jhpulley
Nov 27, 2010 12:21 AM
