Door locks and window not working again
Old Jan 24, 2021 | 02:37 PM
Originally Posted by win717
I did check that today, 12.6, so I guess the idea of a bad battery is ruled out
Not so fast, load test to be sure.
/tsJUuLu1cw0
Old Jan 24, 2021 | 04:26 PM
win717's Avatar
Thank you I tried that also, only drops to 10.6v
Old Jan 24, 2021 | 06:53 PM
Your master switch should be working now! If not, check connectors to the switch, make sure clean & properly secured.
Old Jan 24, 2021 | 07:49 PM
win717's Avatar
i did pull the master switch out, checked the connections, pulled them out, seemed clean not wet. The only thing i didnt check if there is connection at the door hinge or not or somewhere else I need to check
Old Jan 24, 2021 | 09:20 PM
Does the rke work?
Old Jan 24, 2021 | 09:32 PM
win717's Avatar
the rke?
Old Jan 27, 2021 | 01:45 PM
the rke?
Remote Keyless Entry
Old Jan 27, 2021 | 07:33 PM
win717's Avatar
I don't have a remote, getting one but they said they cant program one till I get the issue fixed
Old Jan 27, 2021 | 07:36 PM
win717's Avatar
I do have a little update, I decided to buy a new master Power Window Switch, hooked it up and now the power locks work as they should (drivers and pass) BUT the drivers side power window worked then stopped working, i unhooked it and hooked it back up and it worked for a little then stopped again, not sure what that means, window motor dying?
Old Jan 27, 2021 | 10:00 PM
Mr_Sandman's Avatar
it's a common issue and mine does this during freezing temps. In fact an issue right now, one I have lived to deal with (no left window, no door lock). It would start working fine again if temps reached 40deg. Used to pull the fuse, however, this no longer corrects the issue.
I know the issue lies in the driver side door, but haven't bothered to tackle as this vehicle has a laundry list of issues. warm weather car
