View Poll Results: A poll
Did your H3 sunroof ever leak
46.25%
Your H3 Sunroof never leaked
53.75%
Voters: 160. You may not vote on this poll
Does/Did your sunroof ever leak?
Old Nov 18, 2009 | 07:29 AM
  #51
Bayrat's Avatar
Where do the drains exit? This thread is scaring me, I got rid a a Jeep due to the Freedom top constantly leaking water.
Old Nov 18, 2009 | 05:52 PM
  #52
valleysniper23's Avatar
i recently started having that problem but i think its cause of some access hole inside thru the sunroof that are clogged up with mudd will try to get some pics and see if it can be fixed
Old Nov 18, 2009 | 06:53 PM
  #53
Bayrat's Avatar
I opened my roof today and found the front drains, little bit of mud in there and how it gets there is a mystery. I cleaned everything and the drains are fine. Could not see the rear drains, may try to locate from below and blow air up through them.
Old Nov 21, 2009 | 01:58 AM
  #54
EGGZZ72's Avatar
Clean the clogged drains and all will be well for you young skywalker!
Old Nov 21, 2009 | 01:59 AM
  #55
EGGZZ72's Avatar
SOMETIMES THEY HAVE TO REPLACE THE ENTIRE DRAIN LINE! My 06' H3 had that problem and never leaked again!
Old Nov 25, 2009 | 08:28 AM
  #56
njhusker's Avatar
Originally Posted by Bayrat
... Could not see the rear drains, may try to locate from below and blow air up through them.
Woah there brother... Do NOT blow up through the line. More than likely the clog is at the exit where mud and road grime can easily splash into the hose end. If you blow up you are risking pushing that clog further up the hose and may have difficulty getting it out.
Old Nov 25, 2009 | 12:57 PM
  #57
kimbob1982's Avatar
i had problem with closing it. i had to take to dealer to get it fixed, after that i don't use sunroof.
Old Sep 14, 2011 | 01:04 PM
  #58
chritch23's Avatar
Default Oxymoronic question...
The real question to ask is: Are your roof drains clogged? By design, the sunroof will have a bit of water infiltration, but the water then needs a place to go. There are two drains in the roof cut-out. If they are clogged with debris(leaf matter or other such debris), then GM designers had the bright idea to have the excess drain INTO the vehicle. It will show up in the driver's foot well and down the right rear pillar and under the rt. rear seat and/or floor... Nice of them to design a system with no redundancy wasn't it? Guess there was too much money going towards hack union labor and not enough left over for research and development. At least now the unions aren't allowed to strike against Government owned GM! Maybe better products are in the pipeline.....we will see.
Old Sep 14, 2011 | 05:24 PM
  #59
WBZ's Avatar
WBZ
Originally Posted by Trey124
What are the odds that I had 2 Slate Blue H3s one was an 06 and this one is the later model 07 and they both leak in the same exact spot. It's driving me crazy, I just want a dry H3. MuddyD thinks its the Slate Blue Paint job, he thinks I should paint it Birch White.
Mine is white and has never leaked
Old Sep 14, 2011 | 08:44 PM
  #60
RavenH3's Avatar
just got my H3 back from the dealership. all four of my sunroof drainage tubes were clogged and water got in my car shorting out my BCM, Ignition and Battery. 06 H3.
