Disconnecting Tow Package Harness (at rear bumper)
Old Jan 2, 2021 | 04:47 PM
Faded501s's Avatar
Default Disconnecting Tow Package Harness (at rear bumper)
I'm getting ready to tow a boat down to Florida and find my Hummer is victim of another design flaw. The trailer wires have been eaten through at the frame and for the life of me I've not been able to disconnect the wiring harness plug-in to fix it. I've tried a couple different things but am always afraid of using too much force and breaking the clips. If anyone has any insight it would be greatly appreciated. Thanks in advance!
Below is a (crappy) picture of the clip. I'm trying to fix the problem found in this thread.
Old Jan 2, 2021 | 06:52 PM
Heavy-Duty Trailer Wiring Package
The trailer towing harness contains the following
seven trailer circuits:
• Yellow: Left Stop/Turn Signal
• Dark Green: Right Stop/Turn Signal
• Brown: Taillamps
• White: Ground
• Light Green: Back-up Lamps
• Red: Battery Feed
• Dark Blue: Trailer Brake
Light-Duty Trailer Wiring Package
If your vehicle is not equipped with a trailer
towing package, the chassis harness will
contain the following blunt cut circuits:
• White: Ground
• Brown: Tail Lamps
Old Jan 3, 2021 | 06:37 AM
Justinh's Avatar
To be sure, are you saying you can't disconnect the halves of the plug? Can you not get your finger on that tab in the middle that is on the top (relative to your picture, that is) and press down to release the lock?
Old Jan 3, 2021 | 08:07 AM
Broken Halo's Avatar
Pull BACK (towards the wires you see) on the release tab in the center THEN push down on it.
Old Jan 3, 2021 | 09:07 PM
Faded501s's Avatar
Thanks Justin! You hit it right on the head Broken Halo...much appreciated! Always afraid to manhandle these connectors lol.
Andysworld
Jul 5, 2016 02:39 PM
Shorty
Jul 29, 2015 01:58 PM
HummerTrucksGuy
Sep 14, 2011 07:10 PM
mikeyd
Oct 25, 2010 12:51 PM
mikemsu1
Apr 3, 2007 05:14 PM
