Disabling factory alarm
Old Jun 21, 2021 | 09:43 PM
NFS's Avatar
NFS
Originally Posted by Mittens
This place can program it out of your ECU.
https://www.pcmofnc.com
thank you so much! Did you tune with them before?
Old Jun 22, 2021 | 06:24 AM
Mittens's Avatar
I haven’t yet, but I’m about to. I’m deciding if I’m just going to have the Passlock delete ($75) done or their full performance tune & PL delete ($209). With the old girl having 136k miles I’m leaning toward just the security fix and leaving well enough alone.
Old Jun 22, 2021 | 06:37 AM
NFS's Avatar
NFS
how does it run after their performance tune? Better mileage? Also what’s PL delete?
Old Jun 22, 2021 | 09:59 AM
He thinks you have a pass lock problem............... but that has nothing to do with your aftermarket alarm OEM alarm conflict.
Old Jun 22, 2021 | 10:09 AM
NFS's Avatar
NFS
oh.. well dang lol
I am taking the car o another Best Buy to see if they can figures it out since they cover all park and warranty it
Old Jun 25, 2021 | 12:00 PM
650Hawk's Avatar
The only way to arm the factory alarm is to lock the truck using the factory key fob. If you're not using that to lock the truck, then it "shouldn't" go off when a door is opened. If it does occasionally still go off, then I'm not sure what to tell you.
Old Jun 25, 2021 | 12:21 PM
Broken Halo's Avatar
^^^^^^^^^Not true! I had a Viper remote start (no alarm) installed right after buying my Alpha new in '08. Never have used the factory fobs, only the Viper fob to lock/unlock & remote start. If I use the key to open my driver's door without using the Viper fob to unlock, the factory horn alarm goes off.
Old Jun 25, 2021 | 12:44 PM
Same with aftermarket RKE's. You need to press lock button on the rke to activate the alarm. Lock the doors manually, will never trigger the alarm.
Old Jun 28, 2021 | 05:52 PM
650Hawk's Avatar
Interesting. So the Viper FOB is somehow tying into and arming the factory alarm. First I've heard of that happening. Must be something in the BCM that recognizes the door locks being locked by remote rather than manually.
Old Jun 28, 2021 | 06:20 PM
ALL RKE transmitters have to go through the BCM.
