Cylinder #4 - still buy or pass?
Old Apr 9, 2021 | 07:50 PM
LTDavid's Avatar
Question Cylinder #4 - still buy or pass?
So a stealership has an 06' with under 100k miles and the stealership report says
"inspected for see is on has p0300 stored current tested system found misfire #4 moved coil and plug no change did compression test ok did leak down found exhaust seat leaking need to replace cylinder head"
The sales rep says - it can still be driven for 100k more miles just like it is...
But of course I don't know so I am asking all of you - can you still drive this while you try to see if its plugs, throttle body, etc? Or is this a hard pass?
Old Apr 9, 2021 | 08:31 PM
Old Apr 9, 2021 | 09:52 PM
LTDavid's Avatar
Thank you
Old Apr 10, 2021 | 08:43 AM
LTDavid's Avatar
Hummerz,
Just so I understand, what you're suggesting is that although the leak down test showed (whatever) and the service record says replace head; you're saying that it could likely be fixed by cleaning the internal parts and then using top tier gas?
Other posts show some 06' MY had to have their heads replaced. The last few numbers on this car is: 68275952
I wanted to be sure and clarify - thank you.
Old Apr 10, 2021 | 01:13 PM
Yes, engine decarbonization can correct. No, I would not pay anywhere near the asking price($19,444).
Old Apr 10, 2021 | 01:21 PM
LTDavid's Avatar
Thank you
Old Apr 12, 2021 | 11:22 AM
I would not pay $10K for it as you can buy 06s under that with no problems.
Old Apr 12, 2021 | 12:53 PM
LTDavid's Avatar
The problem is finding low mile h3's... especially since I want the 4:1 transfer case. Not that I do hard core rock crawling but it seems like it would be better to have than not. But I don't know of course - but I do like a lower price tag!
Old Apr 12, 2021 | 07:05 PM
2009 HUMMER H3X later model, rare package, LLR, lower miler, & lower price. Only, 66miles from the '06.
Old Apr 12, 2021 | 09:00 PM
LTDavid's Avatar
Yeah I saw that one - looks good except for now 4:1 transfer case and locker. But looks nice 👍
H3steve
Aug 2, 2020 09:50 PM
Dionta1990
Jun 10, 2019 10:08 AM
tes7996
Dec 23, 2015 11:55 AM
H3MISSY
Mar 4, 2015 09:35 AM
Chad1996
Jan 19, 2015 02:59 PM
