P0304 cylinder misfire
Old Aug 1, 2020 | 04:18 PM
H3steve's Avatar
Default P0304 cylinder misfire
This is a new to me at 150k miles I am trying to being her back to 100%
I am getting an intermittent CEL light for a P0304 - cylinder 4 misfire. The CEL light is random it will be on for a few days then it will turn off .
I just got my BCM replaced by my local dealership they checked out all the cylinders for me and they said that #4 was giving them inconsistent compression tests of 130psi to 180psi at random with a recomendation to replace the head.
The whole random compression thing is really bothering me I dont understand how a cylinder can have this issue.
UPDATE 8/21
I put the recommended amount for Mystery Oil with the engine oil and ran for 200 miles
I ran a can of upper end seafoam cleaner
The CEL for P0304 is still turning on and off around every 4 days, engine seems to run a bit ruff.
I am close to removing the camshaft cover so i can take a look at the upper end. If any one has any thoughts i would appreciate any help I'm sorta stuck right now.
looking for any input
2006 stock h3
150,000miles
new spark plug
New fuel injectors
Checked coil pack
Checked wires to cylinder
Old Aug 2, 2020 | 01:55 PM
H3Luxembourg's Avatar
had the same on Cyl 3, replaced the ignition coil of cylinder 3 and no issues since then.
Old Aug 2, 2020 | 04:33 PM
2006 had head issues. they where recalled. a coil will not fix erratic compression
Old Aug 2, 2020 | 05:10 PM
H3steve's Avatar
I believe my vin # is past the lot of bad heads, I dont believe there was an official recall that would apply to me now?
I am still in question what mechanical issue would cause an intermittent compression instance .
Old Aug 2, 2020 | 05:25 PM
Defective heads would have been replaced by now.
DO MORE RESEARCH, ONLY USE TOP TIER FUEL.
TOO LATE...
NOW YOU NEED TOP ENGINE CLEANER, TO REMOVE THE CARBON DEPOSITS!
DIY, OR TAKE IT TO A SHOP FOR AN INDUCTION CLEANING. ADD A CAN OF SEAFOAM TO THE TANK AND ENGINE. USE TOP TIER FUEL, ETC.. DECARBONIZE, TO FREE THE STICKY VALVE:::::::::>>>16-NA-383
Old Aug 2, 2020 | 07:52 PM
Alex DjFlaco's Avatar
I had the misfire on 2 and 4 and all I did was just change the cylinders and all good.
Old Aug 2, 2020 | 08:04 PM
WTF did you change?????
Old Aug 2, 2020 | 09:13 PM
sorry just saw that. I change the ignition coils and everything worked fine.
Old Aug 2, 2020 | 09:50 PM
H3steve's Avatar
TOO LATE...
Awesome advice and seconds my thinking, I forgot to add that this is a new to me truck and I am dealing with past undoing to her .
Dionta1990
Jun 10, 2019 10:08 AM
juicebox123
Nov 27, 2018 12:38 PM
dlmx
Dec 17, 2016 09:50 PM
norinco3264
Feb 9, 2015 05:00 AM
CrindoTech
18
Dec 18, 2011 03:41 PM
