Codes P0171 P0174
Old Nov 2, 2021 | 06:31 PM
Indskys's Avatar
Default Codes P0171 P0174
I have a Hummer H3 Alpha 5.3l 2008. 172000 miles. Over the last year I have replaced MAF sensor,all O2 sensors All injectors
coil packs plugs,wires all pvc hoses …. Recently I have gotten codes P0171 and P0174. See attachments for fuel trim…
checked for vacuum leaks with carb cleaner couldn’t find any. Still need to check fuel pressure. Any help would be appreciated
2500 rpm
Idle
Old Nov 2, 2021 | 06:54 PM
Check fuel pressure!
Old Nov 3, 2021 | 10:59 AM
reset your fuel trims so that it relearns.
Old Nov 3, 2021 | 11:39 AM
Indskys's Avatar
How do you reset fuel trims? Ty
Old Nov 3, 2021 | 11:52 AM
with a good scan tool like a tech2 or equivalent featured one.
Old Nov 3, 2021 | 04:06 PM
Indskys's Avatar
Reset trims with Tech2. LTFT went back to 27 after a while ran bad at first
Old Nov 3, 2021 | 08:48 PM
then next step is to check your fuel pressure like you stated. or there is an air leak between the MAF and the intake. check the accordion bellows for cracks
Old Nov 5, 2021 | 11:52 AM
Indskys's Avatar
Check fuel pressure not running 60 psi drops to 56 when pump shuts off. Running at idle 60 psi
some needle movement..checked all air intake lines no cracks or issues.
Old Nov 5, 2021 | 11:57 AM
are you sure they sold you the correct parts like the injectors or the MAF? do the injectors CC flow like the originals?
Indskys
Nov 2, 2021 09:26 AM
Infantry11b248h
Jan 26, 2020 10:38 AM
Nick Zubick
Oct 3, 2018 07:51 AM
Fortster87
Jan 22, 2018 06:20 PM
Rp23g767
Sep 19, 2017 10:15 PM
