Code p0400
Old Nov 5, 2024 | 12:44 PM
NFS's Avatar
NFS
Default Code p0014
Just got a code today p0014
i got it before a while back and I did a research some people said it’s the vvt so I changed that and I changed the cam sensors too and the oil
Like few months later I got it today again
anyone knows what else that could be ?
Old Nov 5, 2024 | 01:15 PM
What is the trouble code?
P0400 EGR
P0040 B1S1 & B2S1 connectors swapped.
Old Nov 5, 2024 | 02:13 PM
NFS's Avatar
NFS
Originally Posted by NFS
Just got a code today p0040
P0014 sorry a typo
NFS's Avatar
NFS
P0400 EGR
p0014 sorry a typo
Old Nov 5, 2024 | 02:18 PM
NMH3's Avatar
https://www.dtcdecode.com/HUMMER/Home HUMMERP0014Home HUMMERP0014
HUMMER HUMMER DTC P0014
Make:HUMMER
Code:P0014
Definition:Exhaust Camshaft Position (CMP) System Performance
Description: DTC P0017, P0335, P0336, P0365, P0366 are not set. The engine is running. The system voltage is between 11-18 V. The ECM has enabled the CMP actuator and commanded greater than 0 degrees. DTC P0014 runs continuously when the above conditions are met.
Cause:The difference between the desired CMP and the actual CMP angle is more than 3.75 degrees for 13.5 s.
Related Service Bulletins:
Old Nov 5, 2024 | 02:22 PM
NFS's Avatar
NFS
Make:HUMMER
Code:P0014
does that mean the cam like gets stuck? What can be the fixed for that?
Old Nov 5, 2024 | 03:01 PM
NFS's Avatar
NFS
I replaced that piece when it first came out and changed the oil and everything was fine for a while then I got the code back… so confused is it possible that because the piece is not oem it’s a piece of junk?
Old Nov 6, 2024 | 01:41 PM
Happy Hummer's Avatar
Ding, ding, ding..
Try to get an oem, acdelco.
Also inspect wiring. Verify your receiving proper signals at each wire. Voltage, signal, grnd, etc.
Eurynomestolas
Jun 8, 2023 10:10 AM
fastNYsix
Feb 15, 2022 09:02 PM
ulthummer
Oct 11, 2021 11:23 AM
hummer_on_fumes
Jun 21, 2018 01:10 PM
gotafish
Apr 21, 2012 03:54 PM
