Chime help
Old Mar 1, 2021 | 07:35 AM
b3l14l's Avatar
Default Chime help
Hello. About a week ago I started getting a chime in my 2006 H3 that I can't figure out. When I put the key in (before starting) or when I turn it off, I get 5 consecutive dings, a space, 5 more consecutive dings, a space and then five more. I cannot figure what this is and neither Google or the owner's manual are any help. Does anyone happen to know?
Old Mar 1, 2021 | 07:02 PM
The key in the lock position, and the door LOCK button is activated, you will receive a feedback of 5 chimes.
Old Mar 1, 2021 | 07:51 PM
b3l14l's Avatar
Thank you for the reply. The key is in the lock position for sure because it happens as soon as I put the key in or as soon as I turn it off, but I am 100% sure I am not hitting the lock button. One hand is on the wheel and the other on the key. I wonder if there is an issue with the switch panel? And it doesn't do it every time. I'd say maybe half the times I drive it happens.
Old Mar 1, 2021 | 08:26 PM
Process of elimination: remove & disconnect the master switch.
Old Mar 2, 2021 | 05:36 AM
b3l14l's Avatar
Got'cha. I decided to get a new one just in case. $30 and it'll be here tomorrow so I'll see if it still does it after I put that in. If it does, I'll go from there. That you for your help
Monica Brown Clayton
Oct 31, 2015 11:37 AM
4Scargo
Dec 28, 2013 09:18 PM
cpgmotors
Jul 6, 2010 11:25 AM
jgk h3
Nov 11, 2009 12:57 PM
cpc815
Sep 15, 2008 03:11 PM
