changing oils..
Old Dec 5, 2020 | 12:15 PM
UcraDen's Avatar
Default changing oils..
H3, 2007, 3.7l automatic transmission
I want to change the transmission and transfer case oil. All other oils has been done. Since I have no idea when it has been done lately and previous owner didn't take proper care at all. Also transmisión doesn't smell kosher, altrough the color is fine. I don't want completely flush it, I just want to change the filter and whatever will drip out from the pan.
. so my question- the transmisión always has been for me mystery for me, and if I was doing similar work on it, I usually was buying the oil directly from diller- that correspond to wehicle. Should I do the same? Or i can put any ATF oil? Same thing with transfer case? If I can put different oil which one? What type? Should I go to full synthetic?
Tnx in advance.
Old Dec 5, 2020 | 03:57 PM
wpage's Avatar
This has been coverd B4...
If you search it there are a few.
Short answer is Use the GM recomended fluids for both. Its the same ATF for Transmission and Transfer Case. There is a good deal on Amazon for the Transmission kit with gasket and filter.
Old Dec 5, 2020 | 04:06 PM
UcraDen's Avatar
O! You actually covered my 2d question i forgot to ask- if I have ro get a new gascket
Thank you
Old Dec 5, 2020 | 05:03 PM
The links are still active: ATF & Filter change
Thank you
Look at above thread, get the filter/gasket kit and 2gallons of dex vi.
Old Dec 7, 2020 | 11:26 AM
If you are going to drop the pan and change the filter you might as well add a drain bung to the pan too.
Old Dec 7, 2020 | 11:44 AM
Broken Halo's Avatar
Old Dec 7, 2020 | 11:51 AM
UcraDen's Avatar
Ыыы-ыыы-ююю- жжж
Anyways, I saw those filter kits coming with gasket and the buttplug so ill get the whole thing
Old Dec 19, 2020 | 06:20 PM
UcraDen's Avatar
Change those. The transfer case oil was all pearly- i guess good thing I did it. I was surprised the drain plug didn't have any magnet.
As of transmisión, I drop the pan, and refill the same quantity that was in there (maybe overfill it 100-200g. But after I defenelely could feel that the transmisión start to shift smoother...I wonder if I should to repeat it (without changing the filter) since I didn't flush it all. The magnet was all fluffy with steel particles..
Old Dec 19, 2020 | 08:47 PM
Simple 3 step process: Clean, Exchange, Change filter!
Old Dec 21, 2020 | 10:20 AM
If you installed the drain bung in the transmission pan as suggested earlier then just drain and refill again until you have clean red trans fluid. It takes me 2 or 3 pan drains to get the perfect red (new fluid) color.
cac555@aol.com
May 31, 2017 08:56 PM
reignla
Aug 7, 2015 10:26 PM
jvorpahl
Nov 30, 2014 04:17 AM
HummerH2
Oct 27, 2011 07:22 AM
BIGT2148
Feb 4, 2010 01:42 PM
