changing oils..
H3, 2007, 3.7l automatic transmission
I want to change the transmission and transfer case oil. All other oils has been done. Since I have no idea when it has been done lately and previous owner didn't take proper care at all. Also transmisión doesn't smell kosher, altrough the color is fine. I don't want completely flush it, I just want to change the filter and whatever will drip out from the pan. . so my question- the transmisión always has been for me mystery for me, and if I was doing similar work on it, I usually was buying the oil directly from diller- that correspond to wehicle. Should I do the same? Or i can put any ATF oil? Same thing with transfer case? If I can put different oil which one? What type? Should I go to full synthetic? Tnx in advance. |
This has been coverd B4...
If you search it there are a few. Short answer is Use the GM recomended fluids for both. Its the same ATF for Transmission and Transfer Case. There is a good deal on Amazon for the Transmission kit with gasket and filter. |
Originally Posted by wpage
(Post 380006)
If you search it there are a few. Short answer is Use the GM recomended fluids for both. Its the same ATF for Transmission and Transfer Case. There is a good deal on Amazon for the Transmission kit with gasket and filter. Thank you |
(Post 380006)
Originally Posted by UcraDen
(Post 380007)
O! You actually covered my 2d question i forgot to ask- if I have ro get a new gascket
Thank you |
If you are going to drop the pan and change the filter you might as well add a drain bung to the pan too. ;)
(Post 380054)
Anyways, I saw those filter kits coming with gasket and the buttplug:) so ill get the whole thing |
Change those. The transfer case oil was all pearly- i guess good thing I did it. I was surprised the drain plug didn't have any magnet.
As of transmisión, I drop the pan, and refill the same quantity that was in there (maybe overfill it 100-200g. But after I defenelely could feel that the transmisión start to shift smoother...I wonder if I should to repeat it (without changing the filter) since I didn't flush it all. The magnet was all fluffy with steel particles.. |
(Post 380407)
(Post 380407)
