Can I install a used FPCM from same truck/engine without programming?
Old Sep 1, 2025 | 08:53 AM
freakdaddy's Avatar
Default Can I install a used FPCM from same truck/engine without programming?
My FPCM is bad and if I get a used one from the same make/model Hummer will it work without programming it?
Old Sep 1, 2025 | 04:42 PM
it might still need vin number coding but they do sell ones that do not or come coded for you.
Old Sep 2, 2025 | 10:29 AM
What is the F for? 2006s have 2006 only PCMs. 2007s have 2007 only PCM, 2008 - 2010 have the same PCMs and use a TCM to control the AT.
Old Sep 2, 2025 | 02:00 PM
i beleive it is the Fuel Pump Control Module "FPCM".
Old Sep 3, 2025 | 12:18 PM
Ah......... my bad. Not too common for H3/H3Ts to need one.
Old Sep 3, 2025 | 07:08 PM
NMH3's Avatar
Cool
I was today days old when I learned that the H3 got a FPCM starting with the 2009 model year. Whadayaknow.
Old Sep 4, 2025 | 02:25 PM
Well, after reading a couple posts about this it now has popped back into my memory that back when I was using HP Tuners on my 09 Alpha it does show that module when you get ready to load a tune, and you want to uncheck it because you are not going to make any changes and if you leave it in as a module to write, you have to buy another HP Tuner credit for nothing. I do not recall seeing that on earlier H3s, so it all starts to make sense... sort of.
Moe.H1
Oct 20, 2016 11:57 AM
marine60
Apr 22, 2015 07:45 PM
Cruize
Sep 20, 2013 12:06 AM
MrEnzo
Sep 29, 2011 08:25 AM
gcompton
Aug 29, 2010 08:33 PM
