Brake job nightmare
Brake job nightmare
I have an 07 H3 with 191,000 mi. Just replaced both front brake hoses, calipers, rotors and pads. Getting all kinds msgs on the dash. brake fluid, stability control, traction control. Both the traction control and brake lights are on in the dash. The brake fluid level is good. I tried to reset the computer by disconnecting the battery (for 30 sec). I have a OBD reader and tried resetting any codes...there are none. Does anyone have any suggestions? Thanks in advance.
The best part of diy, there was a problem, and you received an error message, and in your case, traction control. No codes=No electronic failure.
Traction control found a variance in 1 of 4 wheels when you were braking on your test drive.
You found it and corrected it, and saved yourself a lot of money. No lights, stiff pedal, you can drive safely now.
We like it when owners come back and let the rest of us know it worked or not.
martymrgrin
02-21-2013 06:43 PM
