BCM replacement
Old Feb 26, 2022 | 03:58 AM
Boomerang 86's Avatar
Default BCM replacement
2009 H3 Vortec 3700. Randomly burps on Passlock which locks out starter for ten minutes and occasionally see security light come on a few seconds while driving. Got new BCM and fobs from Rockauto. Been holding two good keys near Passlock sensor since, stranded less often.
Scan tool is Thinkscan Plus S7, supports key and fob programming. Do I still have to visit a GM shop to program other attributes?
Old Feb 28, 2022 | 11:11 AM
"Passlock Sensor"?????????
Have you cleaned the ignition switch connections? That's all it should take. See Hummerz photo contribution below....
Old Mar 4, 2022 | 07:24 AM
Ran my VIN at a GM dealer. The BCM is one of two applications, I bought the wrong one. Correct part is on the way. Will attempt again next week
For what it's worth I replaced the multifunction switch earlier, the connections should be ok.
Boomer
Old Mar 4, 2022 | 09:11 AM
So you are guessing if your 13 year old harness connection to the switch is 100% clean.
There is no passlock sensor, H3 keys have NO Chip.
Good luck.
Old Mar 4, 2022 | 10:08 AM
Good luck.
It wouldn't surprise me if there's more electrical gremlins in this old vehicle. Thanks for this. I'll follow up when I get the new one installed.
Old Mar 4, 2022 | 05:20 PM
I get by with a little help from my friends
lucamlenti
Dec 13, 2024 10:04 AM
H3steve
Sep 28, 2019 12:10 PM
TheLion
May 29, 2019 09:50 AM
FloridaH3t
Hummer H3T
20
Oct 24, 2018 08:54 PM
Steve.in.Roanoke
Nov 10, 2016 11:15 PM
