Battery reaching end of life?
Old Dec 15, 2020 | 07:28 PM
omedus's Avatar
Default Battery reaching end of life?
If I don’t start my truck in one or two weeks the battery dies. might be getting close to three years.
I last bought it from the dealership, any recommendations what to get next and where?
2007 H3, 113k, Factory Radio
Old Dec 15, 2020 | 08:54 PM
Deka
Battery is encased within an Active Cooling Box with an air snorkel to the outside of the engine compartment; OE Exact Fit; Battery located in engine compartment.; 30 Month Warranty; Part CCA: 690; Cranking Amps: 850; Reserve Capacity: 95; OE Group: 86; OE CCA: 640
Old Dec 16, 2020 | 08:40 AM
Most Auto Parts stores (regional/national chains) will replace your battery free after you buy it from them. Three years is no worries unless you have let it die repeatedly. I had one that went 9 years before it puked in one of the kid cars.
You may have a parasitic drain that needs to be tracked down. If you are still using the OEM Crappy Azzed Battery Terminal Connectors, I would immediately replace those with a quality aftermarket set like Stingers or your favorite brand and see what that does for your problem. Known #1 mod needed for every H3/H3T Colorado/Canyon. Search it out and you will see just how crappy the OEMs are.
Old Dec 16, 2020 | 01:29 PM
You have a parasitic draw on your electrical system.
What is not stock? Radio, amp, alarm, lights, any switches in the interior, etc?
Old Dec 16, 2020 | 08:53 PM
2 weeks, not a parasitic draw! I recommend to monitor battery voltage! This past year was mostly 1-2 mile trips, shut off, restart, drive home. I never gave the alternator enough time to recharge the battery. I give the battery some attention when I see 12.2v with an all day 2amp charge.
Here's a cheap(less than $5) voltage tester without opening the hood + battery voltage chart:
Old Dec 17, 2020 | 10:04 AM
There are a bunch of I5 H3s that have suffered the parasitic draw problem. Some caused by the rear wiring harness to the license plate light rubbing the chassis = short, poor Battery Terminals Connectors making inconsistent input/output voltage, wet BCMs and/or TCCMs including the harness to them. That is before we even think about aftermarket add-ons.
omedus, when you start a thread asking about your H3....... always: Year; Model (H3s 4); Miles; recent mods and or work done that may impact your issue.
Old Dec 18, 2020 | 09:05 AM
omedus's Avatar
Thanks guys.
A few years ago I had parasitic draw after
installing aftermarket radio, put back factory radio and new battery.
Dealership thought it was the aftermarket radio, everything else is original-
Does that mean I can never install aftermarket radio I wanted one with the camera
Old Dec 18, 2020 | 10:31 AM
Originally Posted by omedus
Thanks guys.
Either it was installed incorrectly or it may have been the adapter harness or possibly have been a bad head unit.
I have an Alpine ilx-w650 with a backup camera like a ton of other people here, no issues.
Old Dec 18, 2020 | 06:41 PM
wpage's Avatar
The nasty thing with battery.
They get old and die.
The demise of the new tech move as well...
Old Dec 18, 2020 | 08:08 PM
No lift needed to replace battery on the H1-2-3
Wait for it..................GMC HUMMER EV Kicks Off Winter Testing
