Anti theft
Old Sep 9, 2020 | 04:08 PM
sean4570's Avatar
Default Anti theft
Today was the second time in about two months I went to start and nothing, Icon on dash showing a car with lock thru it.
I checked the manual and tried every thing listed to cancel it.
About 20 minutes later I was able to start it.
Any thoughts?
Old Sep 9, 2020 | 06:41 PM
RKSmith163's Avatar
Use the Search Function keyword Passlock.
Old Sep 9, 2020 | 08:05 PM
Pull ignition switch connector, clean contacts, reconnect. Done!
Almost forgot.....My favorite contact cleaner/dielectric grease, that's never let me down:
Old Sep 10, 2020 | 10:02 AM
CRC makes good stuff.
Old Sep 10, 2020 | 03:07 PM
sean4570's Avatar
I did the search pass lock a ton of info (almost too much). Where is there info about doing the cleaning route first?
Thanks all for assistance.
Old Sep 10, 2020 | 03:27 PM
Search how to change H3 Hummer ignition switch. There is a recent thread here with a YTube vid in it as well.
Cleaning ain't rocket science..... Get the switch out, clean it and the contacts etc, install it. Test.
Old Sep 10, 2020 | 03:51 PM
sean4570's Avatar
Default H3 Ignition switch change
I did a search on changing out the ignition switch. Most are 8 years old,.
Will cleaning be a solution?
Old Sep 10, 2020 | 05:04 PM
I have a good working backup ignition switch I replaced 8yrs ago if you want it. Just pull the connector and clean terminals, wait a minute, reconnect, then start. Amazing how that works.
Old Sep 11, 2020 | 05:29 AM
sean4570's Avatar
I appreciate the offer, But I will try the cleaning option this weekend. I do have a can of contact cleaner around.
Do you know of any videos showing the process? Should the battery be disconnected before starting switch removal?
Old Sep 11, 2020 | 09:51 AM
From June 2020 ..... Ignition Problems
