Another 2006 misfire question
Old Apr 1, 2021 | 02:19 PM
Jruta's Avatar
Default Another 2006 misfire question
Hi all.
2006 H3 I5, 95.7xx miles.
Runs rough with obvious misfires, feels like it’s gonna stall (sometimes does) but not always.
It tends to smooth out with raised RPMs
Hot or cold doesn’t SEEM to matter but truck can be running like death and within a few minutes it smooths out and purrs at 700 rpm. It USUALLY smooths out after being driven for a while, and then will run like crap even when warmed up if it is briefly shut off and restarted minutes later.
I scrubbed the (filthy) throttle body and cleaned MAF small improvement but not much. Also used Marvel mystery oil in fuel and oil.
I replaced the crankshaft sensor and did the manual relearn.
Read codes:
P00106 (manifold absolute pressure/ barometric)
P0121 (throttle/pedal position sensor)
P0300 (random multiple misfires)
P0017 (crankshaft position/ camshaft position)
Not sure of next step?
Plugs?
Coil packs?
Vacuum lines?
Or does it seem I’m facing the dreaded valve problem?
Thanks in advance.
John
Old Apr 1, 2021 | 04:06 PM
Old Apr 1, 2021 | 04:53 PM
Jruta's Avatar
thank you
Jbrashers
Nov 21, 2019 09:32 AM
ethan1893
Jun 23, 2017 07:22 PM
arcaro
Apr 19, 2016 12:15 AM
spb4444
Oct 26, 2015 09:42 AM
groomsxxx
20
Dec 6, 2012 12:19 PM
