Almost overheated
Old Jun 28, 2021 | 08:01 AM
  #41
Click on the Blue ECT I posted above for more information. 2 pin oval connector mounted on the head.
Old Jun 28, 2021 | 07:18 PM
  #42
Thatsgr8's Avatar
Exact part I thought it was. Will a higher temp cause that part too fail? Highest since owning was around 228 (guessing). It was a tic below needle pegged too hot. I heard the three chimes then I turned off the AC.
Old Jul 1, 2021 | 07:18 PM
  #43
Thatsgr8's Avatar
Took it out yesterday for some food. It was 30 round trip. On the way there I was at 198 until one block away, it shot up to 210. On the way home it was 216-220. It was 98 degrees outside and almost no humidity. I put a new OEM rad cap on this past Saturday. Is this a temp I should get used to during the summer? Seems on the higher side to me. One thing to add, the temp did not drop but a degree at 65+ speeds. Stayed around 215-218. Creeped up at the first stoplight. Should Look into a pusher fan?
Old Jul 1, 2021 | 08:21 PM
  #44
Your temps are still up and down. Do you own an infrared thermometer? Check inlet and outlet temps on the rad!
Old Jul 2, 2021 | 01:02 PM
  #45
Thatsgr8's Avatar
https://youtu.be/KoT-PWg8Ahs
https://youtu.be/bKxsUwa-0uU
I will be buying one soon. What am I looking for?
Old Jul 2, 2021 | 01:07 PM
  #46
Temp drop. Did you watch the 1st video above? fast forward to 4:00.
Old Jul 3, 2021 | 05:48 PM
  #47
Thatsgr8's Avatar
I did watch it. I am searching for a good cheap infrared thermometer.
Old Jul 3, 2021 | 07:42 PM
  #48
I just watched the temp drop on my 18oz ribeye while resting.
Old Jul 3, 2021 | 08:24 PM
  #49
Thatsgr8's Avatar
hahahaha
Old Nov 26, 2022 | 01:05 AM
  #50
finall's Avatar
And OP disappears without posting the conclusion. Just like turning off a crappy movie before the ending.
what happened?
H2sick
Aug 17, 2020 07:24 PM
Hoff
May 29, 2018 06:00 PM
johnnyreno
Jan 14, 2015 03:16 PM
blackbeauty
Jul 30, 2013 08:11 PM
RealJeep
30
Jul 1, 2011 09:24 AM
