Almost overheated
I'm in SoCal; it's been ridiculously hot over the last couple of weeks (105+ for all of last week). My Alpha runs between 195 and 210 (per Torque app) all day long, with the A/C on. Only time I've had to shut the A/C down was a few years ago, driving slowly in a parade (pulling a Boys & Girls Club float/trailer) during 100 degree weather. Even then, it only got to about 220; temps dropped when I turned the A/C off.
Remove cap on radiator cold and make sure coolant is full. You made need to run a few hot cold cycles before all the air is out. That's why professionals use the funnel I posted above, quick way to remove ALL air from the system.
Took it for a drive yesterday after changing the spark plugs. The ones removed had a huge gap. It was above .50. I couldn't even measure it. The temp climbed to 195-197 and stayed there. Ran so much better. Throttle response was great. Thanks for all the help.
Maybe spoke to soon. Went to eat this morning. It was a 15 minute ride there temp was same around 197. Hour inside. Drive home climbed to 215 and stayed there. Checked the coolant reservoir level when I got home and it was 3/4 full. Once it cools I will install the new OEM rad cap I bought for it. We'll see what happens from there.
May still have an air pocket? Let it cool and recheck level INSIDE the radiator. Other than that, the ECT could be failing due to overheated contaminated coolant. Just keep a close eye on the coolant level. If the problem persists without coolant level drop, swap the ect!
What is ECT? The coolant did not look contaminated, well at least by the color or clarity. No discoloration at all. The reservoir level was back to normal, just checked. I replaced the radiator cap with the new OEM I have.
Nevermind, I just looked up ECT which is Engine Coolant Temp sensor. I thought about that as well. Does it sit just above the #1 spark plug?
