AC OFF Appeared ( thermostat and sensor)
Old Dec 21, 2024 | 11:11 AM
ojh32008's Avatar
Default AC OFF Appeared ( thermostat and sensor)
Greetings
thanks all for your support
suddenly during a remote off-road trip the subject alarm appeared. I returned to nearest city I barely found the engine coolant temperature (ECT) sensor and replaced it.
i flushed the old coolant fluid and added new one.
currently the temperature gauge doesn’t exceed 1/4 while driving. When I shutdown the engine then turn the key on before starting the car it’s near 1/2 the gauge.
My questions as follows
does the thermostat linked with the ECT sensor ? Since both happened suddenly in the same time.
can I operate my H3 with 1/4 temp gauge ?
Is there any way that i can fix the thermostat or reset it since it's in open stuck position ?(I guess )
i tried to secure the thermostat but it’s not available i have to order it and it will take time and i need to travel back to my city around 800 miles
Old Dec 21, 2024 | 07:53 PM
BlueH3's Avatar
I get this “AC off” every time I drive when it’s less than 20 degrees out. When outside warms up in day code eventually just goes off. My temp gauge always is less than 1/2 gauge when normal warmer driving.
This happens every winter.,,🤷🏻‍♂️ Why??
Old Dec 22, 2024 | 03:45 AM
ojh32008's Avatar
i had similar issue, I changed the sensor it was working fine, but since the thermostat it’s stuck open the engine can’t get enough heat so it triggers AC OFF.
it is 32 degrees here.
Old Dec 22, 2024 | 12:44 PM
Happy Hummer's Avatar
Thermostat on my 07 was separate from ect sensor. I've replaced Thermostat and it is in a very undesirable location to say the least. Lol...
Old Dec 23, 2024 | 11:42 AM
ojh32008's Avatar
i have ordered new thermostat unfortunately I couldn’t find original one. Once installed i will update
because the new ECT not working as well and the AC OFF still appears
Arthur Kill
Jun 6, 2021 08:41 PM
lilcmtz
Jul 17, 2020 01:18 PM
Hummerforever
Mar 4, 2019 08:22 PM
Jeff Bartnett
Aug 17, 2016 09:06 AM
31sonic
Feb 8, 2012 10:16 PM
