AC OFF Appeared ( thermostat and sensor)
Greetings
thanks all for your support
suddenly during a remote off-road trip the subject alarm appeared. I returned to nearest city I barely found the engine coolant temperature (ECT) sensor and replaced it.
i flushed the old coolant fluid and added new one.
currently the temperature gauge doesn’t exceed 1/4 while driving. When I shutdown the engine then turn the key on before starting the car it’s near 1/2 the gauge.
My questions as follows
does the thermostat linked with the ECT sensor ? Since both happened suddenly in the same time.
can I operate my H3 with 1/4 temp gauge ?
Is there any way that i can fix the thermostat or reset it since it's in open stuck position ?(I guess )
i tried to secure the thermostat but it’s not available i have to order it and it will take time and i need to travel back to my city around 800 miles
I get this “AC off” every time I drive when it’s less than 20 degrees out. When outside warms up in day code eventually just goes off. My temp gauge always is less than 1/2 gauge when normal warmer driving.
This happens every winter.,,🤷🏻♂️ Why??
it is 32 degrees here.
because the new ECT not working as well and the AC OFF still appears
Jeff Bartnett
Aug 17, 2016 09:06 AM
