2009 Hummer H3 with manual transmission has very bad vibration around 2500 rpms
Old May 3, 2021 | 05:59 PM
catate's Avatar
Default 2009 Hummer H3 with manual transmission has very bad vibration around 2500 rpms
We recently replaced a brakes on our 2009 H3 On the front end only did brake pads on the back end we had to replace brake pads rotors and calipers. Now all of a sudden it has a very bad vibration at around 2500 RPMs. When I press the clutch in the vibration stops. Then when I shift gears and get back to 2500 Rpms it starts vibrating again. Anyone have a clue what this may be?
Old May 3, 2021 | 07:16 PM
Old May 4, 2021 | 10:41 AM
Whenever you ask a question, you should include miles on the vehicle.
Old May 4, 2021 | 01:31 PM
did you clean the axel faces when you put the new rotors on? maybe the new rotors are not flush on the axel because of rust or debris. or the back of the rim face might not be flush to the rotor same thing check for rust or debris. torque the lug nuts to spec.
Old May 8, 2021 | 01:58 PM
H3Luxembourg's Avatar
did you bold and torque all nuts /screws well?
daddyhodge
Mar 3, 2017 05:33 PM
ElGuapo
Apr 5, 2012 05:27 PM
Tackleberry
May 11, 2009 07:37 PM
1992 4 Door Hard Top
Dec 29, 2006 08:29 PM
lets get dirty
Oct 10, 2006 12:55 PM
