View Poll Results: Can anyone tell me where the water inside the vehicle is coming from...water enters n
Water inside h3 near emergency break
0%
Driver side H3 water leak near emergency break
0%
How to fix water inside H3 near emergency break
0%
Voters: 0. You may not vote on this poll
2009 H3 water inside vehicle near emergency break
Old Jun 10, 2025 | 11:03 AM
Tootlesh3's Avatar
Default 2009 H3 water inside vehicle near emergency break
2009 H3 has water coming inside the vehicle where the emergency break is....only happens when it rains. Can anyone tell me how to fix this? It is not the sunroof, and the door seals are in good shape.
Old Jun 11, 2025 | 09:18 AM
Welcome to HF.
Water flows down because of gravity. Could be coming from the windshield, from the wiper/cowl well, clogged sunroof drain that has not been maintained, broken RivNut for a Roof Marker Light (you did not specify if you have them), or under the trim along the top fin front of the Roof Cross Bar Track.
Get out a hose, start low, wet the wiper/cowl tray. Stop, get in under the dash with the side kick plate pulled and LOOK. If it stays dry, go to the windshield, them the roof until you see where it is coming from.
Why did you say "it is not the sunroof"? How do you know? Have you done the fix? Have you tested that the sunroof tray drains properly? When was the last time you cleaned out the drains?
Old Jun 11, 2025 | 11:06 AM
Tootlesh3's Avatar
Welcome to HF.
I have done all the test. I watched the last time it rained. I finally was able to see the rain was getting in under the dash right where the emergency break is. A lot and only when it rains. Do you know what I need to do to fix it?
Old Jun 11, 2025 | 11:50 AM
Yes I do.
1) find the source of the leak.
2) repair the problem.
If you followed my suggestions you might get there. Watching in the rain will likely NOT work because the entire truck is getting wet. You were looking at water after it entered, not a point of intrusion.
You need to pinpoint the application of water at specific places one at a time, starting low and working higher while looking for the point of intrusion to find it.
Add to my above list. Remove the left/driver A Pillar Interior Trim to look for the leak source once you get above the wiper/cowl tray.
Good luck.
Old Jun 12, 2025 | 11:51 AM
Yes I do.
X2 on exactly what DOC said.
Follow the steps above to locate the leak. Have a helper with a water bottle or hose on low start from the bottom up and soak each area for 30 seconds while you are in the cab with the door closed upside down with a flashlight looking for water!
Old Jun 12, 2025 | 05:47 PM
NMH3's Avatar
...^^^ This.
Old Jun 17, 2025 | 02:38 AM
smtichy's Avatar
If you haven't done the sunroof fix, meaning opening the headliner and have had a visual that the 100% the sunroof drains are intact. Then that is where I'd start, hose on low around the edge of the sunroof, and confidently eliminate that as the cause.
I had the same issue as you once, heavy rainstorm, water dripping on my feet as I drove. The cause was that the passenger side sunroof drain hose was disconnected, water made it's way inside the headliner, finding the route around to the driver's side and then down the A pillar and out where the emergency brake is.
Justinh
Oct 17, 2022 09:39 PM
Aussie H3
Feb 19, 2022 06:40 PM
omedus
Aug 18, 2021 01:39 PM
win717
Mar 1, 2021 10:44 AM
fishlunch
Oct 19, 2010 10:15 PM
