2007 Hummer H3x Towing Capability
Please clarify the towing capability of my H3x 2007 for a travel trailer gross weight and dry -- meaning no occupants, liquids or personal belongings in the trailer. Some say 3,000#s - others say 4,500 #s???? My engine is an in-line 5 cylinder 242 hp. Hummer in like new condition and completely original - 93k mi white
Research shows I have limited capability of maybe a 21 ft trailer by some manufacturers. Wld like to go to a 24 ft travel trailer. Use will be primarily in FL.
Richard rdi0007@yahoo.com
If your H3X is an I5 A/T and has the tow package, which most do, you have a towing capacity of 4500lbs. Only 3000lbs if it is manual. Obviously if you load your vehicle with an additional 1000lbs of payload plus passengers you will be putting a huge load on your Hummer. Add to that towing in Florida in the summer heat you may want to rethink what you want to do, maybe look into a different vehicle with more towing capacity.
With my 2007 H3X with the I5 and I frequently tow a single axle enclosed motorcycle/utility trailer loaded with 2 full size Harleys, they each weigh about 900lbs. I have an additional 500lbs of gear and tools, and the trailer weighs 1750lbs. That's roughly 4000lbs and I can tell you if there's any kind of hills I have to use D3 and not Drive, otherwise the tranny keeps shifting up and down. This makes for a comfortable 65mph and about 14mpg on the hiway. And, per the owners manual I do change my transmission fluid and transfer case fluid more frequently, about every 20000 miles, to keep it fresh. I've been doing this for about 5 years and have had no problems but I believe my set up is at the high end of what the Hummer H3 with the I5 was designed to handle comfortably.
