2007 H3 - Whine when in gear
Old Apr 25, 2022 | 08:42 PM
dogfan85's Avatar
Default 2007 H3 - Whine when in gear
Good evening all. Looking for some help before taking my H3 in for service. I have a 2007 H3 with 78,000 miles. Original owner with all service completed at GM dealership. The issue I am having is a whine that begins when vehicle is put into drive or reverse. It doesn’t start until then. The whine sound will increase upon acceleration. I honestly don’t think it’s a transmission issue. Trans fluid is fine in level and color. No slippage upon acceleration and no other noises heard. Whine noise predated front and rear differential fluid change a few months ago. I’ve read that it could be the power steering pump (nothing wrong with the power steering); water pump or alternator but nothing seems out of the ordinary with either of those items. I have been on this forum for years and have always used it as a great reference tool. Any help is greatly appreciated.
Old Apr 26, 2022 | 10:50 AM
usually there are only 3 things that will wine in a vehicle.
power steering pump
transmission torque converter
and the spouse.
Old Apr 26, 2022 | 11:53 AM
Add cheese and you are good to go...........
Highly unlikely the T Case is involved, but you did not mention fluid service to that.
Power steering can get noisy when mad.
Old Apr 26, 2022 | 12:22 PM
Date PublishedFEB 01, 2011NHTSA TSB #10038349
TSB# PI-0153B.
Affected Component: POWER TRAIN:AUTOMATIC TRANSMISSION:TORQUE CONVERTER
GM: THERE IS A WHINE NOISE WHEN IN DRIVE OR REVERSE. THERE IS A BEARING PROBLEM IN THE TORQUE CONVERTER. *RM
Old Apr 26, 2022 | 02:45 PM
dogfan85's Avatar
Haha on the spouse. She drives the H3 and trying to hold off buying a new vehicle based on high prices and low inventory.
Doc, transmission service is the next thing on my list.
HummerZ, I’m hoping it’s the power steering instead but I will check out that TSB.
Thank you to you guys for responding. Like I said before, this is the greatest place for technical know how on all things Hummer!
PS- maybe I can hit the Powerball and afford the new electric Hummer. I’d like to play with the crab crawl function,,,,just kidding.
Old Apr 26, 2022 | 03:16 PM
Power steering noise would happen in park too more noticeable when turning steering wheel. Turn steering wheel to either lock position and you will hear the difference from a power steering whine vs transmission torque converter/bearing/pump whine. Upload a video with clear sound to YT and post here. Listen to this:
Old Apr 26, 2022 | 03:34 PM
Btw, if you verify the noise coming from the transmission, drop the pan first, replace filter & install fresh DEX VI.
Could be fluid restriction to the pump as the source of noise.
Old Apr 26, 2022 | 03:43 PM
+add a can of TransTune
Old Apr 26, 2022 | 08:10 PM
dogfan85's Avatar
Thanks HummerZ. No noise (whine) when in park. Did the steering wheel suggestion but no whine heard. I will try to capture the whine on video, post you YouTube and upload. Only when put in gear does the whine start and increases with acceleration. I will change the trans fluid/filter as suggested and report back. Thanks for the suggestion!
Old Apr 27, 2022 | 06:27 AM
Transfer case, when was the last fluid change (as Doc asked previously)? What color was the fluid? What fluid did you refill with?
Magpul
Feb 22, 2022 05:02 PM
MarkMc00
Nov 26, 2019 08:15 PM
skeptic
Mar 16, 2014 10:13 AM
Dondobe
Dec 21, 2011 11:03 PM
dillusion
May 21, 2011 04:54 AM
