2007 h3 traction control
Old Apr 18, 2023 | 11:15 AM
Disel's Avatar
The front locker has NOTHING to do with Traction Control being turned off. I wheeled a 2007 H3 (which have no front lockers) for years and turned off TC AND StabiliTrack regularly.
From the 2007 H3 Manual (for US Made H3s) that apparently is not worth your time? READ THE MANUAL!
"StabiliTrak® comes on automatically whenever you start your vehicle. However, when the transfer case is placed in Four-Wheel-Low Lock mode, StabiliTrak® is automatically disabled.
See Full-Time Four-Wheel Drive on page 111 for more information. To help assist you with directional control of the vehicle, you should always leave the system on. You can turn StabiliTrak®
off if you ever need to using the TC (traction control) on/off button. If you press and hold the TC button for five seconds, the StabiliTrak® system and the traction control system will turn off.
When this is done, the STAB SYS OFF message will be displayed on the DIC.
Press the TC button again to turn StabiliTrak® back on. See Traction Control System (TCS) on page 241."
Although this is not the question hear, you can use HP Tuners to adjust how much if any TC you want.
I can read manuals.
If put the car on its side on two wheels, and two in the air on the jacks, then the car will still jump off the jacks. The system is not 100% disconnected either from the button or with a low gear.
If disable one of the ABS sensors, the system is completely cut off as we would like.
Old Apr 18, 2023 | 12:37 PM
Originally Posted by Disel
I can read manuals.
Oh Boy.
Exactly as expected with no TC because............. H3s are FT 4WD.
Old Apr 18, 2023 | 02:25 PM
I can read manuals.
WHAT THE HELL! If you put ANY full time 4 wheel drive vehicle on 2 of it's "single side" tires it is going to move!
Old Apr 18, 2023 | 07:37 PM
Det2008SUT
Apr 29, 2013 09:19 AM
XxCC3xX
Aug 20, 2011 02:30 PM
fhydro
Dec 6, 2010 01:12 PM
rexnfxs
Jul 17, 2010 02:35 AM
hynesinkc
33
Jan 6, 2008 10:53 AM
