Please help h3 transfer case leaking output seal
Old Apr 14, 2023 | 12:16 AM
Sucker4blondz's Avatar
Default Please help h3 transfer case leaking output seal
Was making noise so changed torque converter and now all back together now I'll push up from transfer case is leaking so changed it with a new one from dealership and still leaking so try another one from Advance Auto and still leaking don't know what to do is transfer case bearing or something else bad inside tried sealing with silicone and still leaks any help would be appreciated greatly because my mom is about to get a transfer case from junk yard and she doesn't really have the money to waste for something stupid
Old Apr 14, 2023 | 09:53 AM
Welcome to HF. I MOVED this for you to the H3 section, where all H3 questions go.
I read English, but cannot understand what you are saying???? Perhaps slow down and provide accurate information. Example, what does "now I'll push up from transfer case is leaking" mean? What does a torque converter have to do with the transfer case output seal?
Old Apr 14, 2023 | 12:22 PM
Disel's Avatar
Check the play of the transfer case shaft. If there is, then you need to open and eliminate
Old Apr 16, 2023 | 04:13 PM
Justinh's Avatar
A pic would be nice. Did you change the seal or someone else?
Old Apr 19, 2023 | 01:05 AM
Sucker4blondz62386's Avatar
Default Ok ill try to see how much play there is
kk
I appreciate any help I'm sure you understood the post even though I talk texted it and some came out wrong I had to drop the transfer case to get the transmission down to change the torque converter and ever since I put the drive shaft back in to the rear of the transfer case it's been leaking and it didn't leak before so I did a new seal and is still leaks and try two more from dealership and one from another auto parts store and it's still leaks i appreciate your time to help figure this out
Old Apr 19, 2023 | 01:07 AM
I changed the seal and then it still leaked so I tried 2 more from dealership and another from auto parts store
Old Apr 19, 2023 | 10:24 AM
The old seal may have chaffed the shaft enough to make it smaller in diameter where it now sits on the shaft. Hence the leakage.
Might have to replace the shaft or find a smaller diameter ID seal with the exact same OD as the OEM.
I have seen it on pinion yolk shafts, CV shafts, etc. Sand and dirt with dolomite, granite and other hard stone in the mud can be very abrasive.
Old Apr 19, 2023 | 10:44 AM
Default Thanks
thank you I appreciate the help I'll see if I could find one and try that and what's the drive shaft out there is a little play on the output shaft not a lot but when you put the drive shaft in there's very little play almost none
CarlosC
Jul 2, 2023 10:46 AM
PGI Conch
Apr 1, 2023 07:06 PM
bigstick0000
Sep 17, 2020 09:29 PM
LatvjuAvs
Jul 8, 2020 01:02 PM
user 956363738
Feb 7, 2013 07:09 PM
