2007 H3 - Pads, Rotor Repair Traction Control Error Now
Hi, thanks for reading. I have a 2007 H3 ~150k miles. 2 weeks ago I had the front break pads changed and also the rotor's replaced. Around the next day
I got the traction control error, been so busy at work I've not had time to bring it in. The error happens allot now and when it goes off you can tell, the car has a shaky feeling.
My questions is,is it possible the rotor work/mechanic did something, can this cause a traction error, related in anyway? I just want to make sure I don't get hosed.
Thanks,
Thanks,
Yes indeed if this issue occurred after the brakes were replaced. Not to worry, light comes on disabling the abs/traction control system. Safe to drive, I'm still alive after driving many different vehicles since the '70's that didn't have traction control/abs systems. Take it back to your mechanic asap. GL
byeatts
09-18-2017 04:15 PM
