Traction control failure ,no Low 4x4
Old Sep 11, 2017 | 11:44 AM
byeatts's Avatar
Default Traction control failure ,no Low 4x4
Recently had the traction control failure light come up and it no longer shifts to low range either, Any idea what causes both to fail? 06 H3 with 30K miles
Old Sep 12, 2017 | 05:06 AM
Possible ABS issue. Check all 4 wires that connect to the sensors (tone rings) on you axles.
Old Sep 17, 2017 | 05:44 PM
byeatts's Avatar
Tainter was correct, found broke wire and now shifts in Low! thank You. However my traction control failure light is still on, Do I need it flashed?
Old Sep 17, 2017 | 08:46 PM
After so many run cycles it should clear. Have someone with a code reader clear them if you can.
Old Sep 18, 2017 | 04:15 PM
byeatts's Avatar
Tainter is correct again. The Traction light cleared and now no need to take to GM Thank You,,,,
Marcieannt
Jan 27, 2016 10:58 PM
Shorty
Jun 23, 2015 09:12 AM
brachilius
28
Feb 3, 2011 08:04 AM
GarrettMoore
18
Sep 12, 2008 05:01 PM
