2007 H3 - Pads, Rotor Repair Traction Control Error Now
Old Jun 13, 2019 | 11:02 AM
Catdaddy's Avatar
Default 2007 H3 - Pads, Rotor Repair Traction Control Error Now
Hi, thanks for reading. I have a 2007 H3 ~150k miles. 2 weeks ago I had the front break pads changed and also the rotor's replaced. Around the next day
I got the traction control error, been so busy at work I've not had time to bring it in. The error happens allot now and when it goes off you can tell, the car has a shaky feeling.
My questions is,is it possible the rotor work/mechanic did something, can this cause a traction error, related in anyway? I just want to make sure I don't get hosed.
Thanks,
Old Jun 13, 2019 | 11:22 AM
Check the ABS wires on the front hubs and in the rear.
If they messed with the wires or connections you could have a frayed wire.
Not properly bleeding the system can also be a culprit.
Old Jun 13, 2019 | 12:06 PM
Catdaddy's Avatar
Thanks so much, I will ask them about it. Do you think its safe to drive for the next day, or is this an issue where you don't touch the car?
Old Jun 13, 2019 | 02:55 PM
Yes indeed if this issue occurred after the brakes were replaced. Not to worry, light comes on disabling the abs/traction control system. Safe to drive, I'm still alive after driving many different vehicles since the '70's that didn't have traction control/abs systems. Take it back to your mechanic asap. GL
Hhummer
Mar 13, 2019 09:38 AM
jd1368
Feb 18, 2019 04:43 PM
byeatts
Sep 18, 2017 04:15 PM
maz722
Nov 4, 2011 11:02 AM
fhydro
Dec 6, 2010 01:12 PM
