2006 H3 3.5L in Miami
Old Mar 18, 2022 | 06:43 PM
Lfernandezjr3's Avatar
Default 2006 H3 3.5L in Miami
Back in Miami with the 2006 H3 3.5L.
I dropped off the H3 at the shop. Did a bumper to bumper vehicle inspection with the tech. This was why we found that needed fixing
1. Fuel Pump
2. Power Steering pump
3. Rack and Pinion
4. o2 Sensor (removed siezed sensor)
5. Thermostat (no thermostat)
6. PVC Valve
7. 5-Coils
8. Wheel Alignment
Total job labor and parts $2,100.00
The cool thing is that mechanic got the o2 sensor out!!!
No one wanted to fix the o2 sensor.
A mechanic told me that I had to replace the exhaus manifold and the cat. Wanted $1,400 to do the work.
Thank you all for your time and interest with my H3 3.5L.
Regards.
Old Mar 18, 2022 | 07:19 PM
How much for the "PVC" valve?
Old Mar 21, 2022 | 10:05 AM
1. Fuel Pump
3. Rack and Pinion
6. PVC Valve
7. 5-Coils
8. Wheel Alignment
Regards.
Just from the fact he said PCV valve (I5s don't have one). I would be leery of every other item on this "mechanics" list.
1. Fuel Pump why? leaking, rotted lines, pressure test done, etc.
2. Power Steering pump why? Leaking, whining/groaning, etc.
3. Rack and Pinion why? Leaking, excessive movement (could be the clamp, known issue), etc.
5. Thermostat (no thermostat) How did the "mechanic" come to find this out? remove the housing?
6. PVC Valve no PCV calve on the I5 H3s
7. 5-Coils Why all 5 coils? Also weird no plus but all the coils.
8. Wheel Alignment Always a good thing
Old Mar 22, 2022 | 06:08 PM
Justinh's Avatar
The t-stat is built into the housing, right? If no t-stat, then it must not be an OEM-style housing, or else someone took the time and effort to remove it. Overheating problems?
Old Mar 22, 2022 | 06:28 PM
Default Overheating
Hello Friend.
It did not overheat. I did noticed the the nittle didn't go pased the first line. Now, the needed is showing close to the mid point.
According to the mechanic. The thermostat was removed.
Mike2008
Jan 8, 2025 12:41 PM
Jruta
Apr 2, 2021 07:58 PM
C31322
Sep 11, 2013 03:27 PM
