12v switched (acc wire) in dash, please help!
Old Jan 8, 2012 | 10:29 AM
jbs45's Avatar
Exclamation 12v switched (acc wire) in dash, please help!
I've been searching for an hour on here and can't find a straight up answer. I need to find a switched 12v power source in the dash area. I'm adding a backup cam to my factory headunit, but can't find a good switched power source. I have tested many wires with my meter but none have panned out. None of the wires on the radio power harness had a switched 12v function. I have the factory navi headunit with monsoon sound system.
I read where someone suggested using the red/white wire in the radio power harness. There is no red/white wire on my radio harness.
Please help, my dash is torn apart until I solve this dilemma.
thank you in advance!
Old Jan 8, 2012 | 11:00 AM
talusfan's Avatar
Try one of the wires for the trailer brake controller up by the gas pedal
Old Jan 8, 2012 | 11:09 AM
Mr. Fancy Pants's Avatar
Or use your meter and find a spare switched 12vdc on the fuse panel. My backup camera utilized the power from the reverse light which only supplies 12vdc when in reverse. Why don't you use that?
Old Jan 8, 2012 | 04:18 PM
jbs45's Avatar
In case anyone cares, I found a +12v switched (acc) wire under the emergency brake area. There is an unused blue harness with two wires that are both +12v switched.
Old Jun 23, 2012 | 11:37 AM
Azrael2004's Avatar
Thanks, I was just looking for the same thing!
Old Jan 1, 2014 | 02:41 PM
Brent Whitfield's Avatar
thank you jbs45. been trying to find the same thing
Old Jul 3, 2022 | 02:44 PM
rswizards's Avatar
what wires under the e brake?
Old Jul 3, 2022 | 06:52 PM
You posted in an OAF H3 thread.
IGSW+wires available under the dash>>>>>>>H3:
Old Jul 5, 2022 | 08:49 AM
Yep................ dug up an EIGHT YEAR OLD THREAD to add a question????????????
nelly27281
Jun 16, 2015 04:29 AM
Boyd2004H2
May 19, 2013 02:29 PM
SedonaBoundH3
Apr 13, 2012 02:21 PM
jbs45
Jun 15, 2010 09:50 PM
Autumn Walker
Mar 26, 2010 02:17 PM
