At 109k and not sure if trans fluid/filter has ever been changed. Change or leave it?
Old May 8, 2026 | 05:18 PM
NMH3's Avatar
Originally Posted by Tonyp25
Got it! I was thinking that with the drain plug I could drain it at each of my next two oil changes to really replace the 11 or so quarts that it holds. And then hold off to do the filter again at closer to 50,000 miles.
If I was you I would just use the MityVac you have access to and suck up what's in the pan, then top it back up based on how much you extracted. Do a hot fluid level check as described in the owner's manual before you start so you know you are starting with the correct fluid level.
When I dropped the pan and did my filter I replaced 5qts of fluid. When I siphon the pan with a MityVac I get about 3 qts out. The filter isn't much more than a screen, so I doubt its removing fine particles or likely to become clogged if you left it in there. Pretty sure its to capture larger chunks while the magnets capture the fine particles.
Old May 8, 2026 | 06:28 PM
MONITOR THE COLOR OF THE FLUID & KEEP IT RED!
wpage
Jan 18, 2025 08:18 AM
cjd9153
20
Jun 3, 2019 01:28 PM
2005H2
Nov 16, 2016 06:57 PM
H2Miami
Oct 28, 2014 09:10 PM
TXH2SUT
Jun 30, 2009 07:03 PM
