DIY Transmission pan drop filter change. Any tips?
Old Jan 3, 2025 | 02:19 PM
wpage's Avatar
Question DIY Transmission pan drop filter change. Any tips?
Hey Folks,
So considering doing a transmission filter change. In my driveway. Or garage.
Any suggestions or tips. Will be doing it up on drive up ramps if I go ahead. I have a H3 with the 3.5 on a 2006 model. I do my own oil changes and have done the half assed trans fluid suck outs every 50K.
Thanks for your consideration...
Old Jan 3, 2025 | 03:06 PM
Alpha X's Avatar
While you have the pan off, add a drain plug to make it easier next time. I drilled a hole in the middle of where the round magnet is located inside the pan, and added this:
Dorman 65128 Transmission Oil Drain Plug 1/2-20
Amazon Amazon
Old Jan 4, 2025 | 10:55 AM
Justinh's Avatar
@Alpha X did you do anything special to keep the plug from leaking (at the pan or at the plug)? I've had trouble with these before.
@wpage suck out as much fluid as you can first. Although the job is easier if you remove the front prop shaft, it can be done w/o removing it.
What type of pump and tube do you use to suck out fluid?
Old Jan 4, 2025 | 03:47 PM
wpage's Avatar
Thanks for the feedback guys. Not looking to add a plug. This is not something for my needs that I do often. ( Almost 20 years and just getting around to changing the filter.)
Since Im not big on gaskets and pans and alterations. Just looking to see if I sould do this in the house or out source. To the pros. I am technically competent but not looking to get a leak after messing with this.
I have gasket seal and not apposed to getting some hot fluid on my self and floor. Wondering what tips from some who have done this as like... Side wind the drop on the pan etc...
Thanks!
Old Jan 4, 2025 | 04:47 PM
DIY, so you know it's done right!
First add a can of Trans Tune then drive a couple hundred miles.
GET A QUALITY FILTER GASKET KIT!
Thoroughly clean both transmission housing & pan surfaces also replace the filter seal!
Reinstall the pan with gasket properly secured in place, install the bolts hand tight all around the pan then properly torque the bolts.
Fill with DexVI start run to operating temperature while checking fluid level also check for leaks at the pan gasket- Check torque at the pan bolts when heated which only needs 9-12ft.lbs.MAX (DO NOT OVER TIGHTEN).
Old Jan 5, 2025 | 07:50 AM
wpage's Avatar
Default Wow
https://youtu.be/Fnc9KAr1JMg?si=_kgz1b88AG9hjHeL
Hummerz. Thats a wow...
Until the part about dropping the drive shaft it looked like something I could do... Going to have to think about this project. Thanks for sharing !
Old Jan 6, 2025 | 09:59 AM
Make sure to get the AT Change kit that has the H3/H3T only filter. A standard 4L60E filter doesn't work with the specialty shaped H3/H3T Trans pan. Likely you already knew that, but for others they should pay attention to what parts they get for this simple job.
Old Jan 6, 2025 | 02:18 PM
wpage's Avatar
Default Great Tip
Make sure to get the AT Change kit that has the H3/H3T only filter. A standard 4L60E filter doesn't work with the specialty shaped H3/H3T Trans pan. Likely you already knew that, buy for others they should pay attention to what parts they get for this simple job.
https://www.youtube.com/watch?v=9aapxfdAbKs
...Thanks Doc,
Thats a great tip to look for the angle cut on the kit filter. ...
Thanks for sharing the knowledge !
Old Jan 7, 2025 | 07:46 AM
Happy Hummer's Avatar
For your safety plz block wheels. Place plastic sheet down (tarp). Where disposable gloves and clothes because it's gonna get ugly 😆 . Be safe. Have some fun.
Old Jan 7, 2025 | 06:50 PM
Alpha X's Avatar
Yes, good point Doc.
GM & AC Delco 24225323 is the part number you want.
Amazon link for this filter and gasket kit below:
Amazon Amazon
