07 Hummer H3
Old Sep 3, 2020 | 01:36 PM
Angel Cifuentes's Avatar
Default 07 Hummer H3
Hummer wont start just hear a clicking sound. I was told it was starter so i changed it and also changed to a new battery. But still have same problem, connected OBDII and got P0449 but was told this should have anything to do with h3 not starting also checked all fuses and everything seems fine. Any other suggestions?
Old Sep 3, 2020 | 01:44 PM
Welcome to HF.
Is the "new battery" fully charged? FYI they do not come that way off the shelf from the auto parts store. Check the oil for level and quality.
Any recent work done, issues happening just before your no start situation occurred?
Are you still using the crappy azzed OEM Battery Terminal Connectors? If so, hack them off and replace with a quality aftermarket set like Stingers or your favorite brand. They are THE #1 mod to do to every H3 as the OEM are garbage and known to fail by creating many electrical Gremlins.
MOVED this for you as the new member section is not for Tech Questions.
hummer_on_fumes
May 9, 2020 05:20 PM
hummer_on_fumes
Dec 7, 2019 08:21 AM
hummer_on_fumes
Oct 11, 2019 11:39 AM
crum55
Aug 17, 2018 06:11 AM
greenb98
Jul 20, 2016 08:27 AM
