07 H3 Coils aren’t getting signal to fire. Hellllllpppp
Old Sep 4, 2019 | 10:27 AM
C50bart's Avatar
Default Misfire
Now that I have it running the truck keeps throwing code 3 misfire. Any suggestions on what to check?
Ordered new fuel rail and injectors, checking for vac leak, changing plug in 3, all new coil packs and hoping I find problem. I can’t get it inspected with idiot light on.
Old Sep 4, 2019 | 10:58 AM
See this thread .... Acts like it wants to stall/rough idle -No CEL -What To Do:
You are overdoing it with throwing parts at it. You should have just swapped Coil Pack on #3 to a different location and see if the misfire followed that CP for the first step. Now that you skipped past that... see where the misfire goes or if it stays at #3.
Next, review my linked thread and the most recent addition by Hummerz. Let us know if you need more help.
Old Sep 4, 2019 | 12:22 PM
C50bart's Avatar
Thanks Doc, I actually did do the swapping of coil packs and nothing happened. Also plugs. However, I just went to autozone and bought Carb cleaner and sprayed the injectors where they meet the head and motor started to reduce idle. I have a vac leak. Being lazy I only inspected the fuel injectors o-rings and they looked good and seated tight. Well I had the new o-rings and never replaced them and now I have double work. I ordered a new fuel rail with injectors off eBay for $50 and going to replace all the O’s on that one then do swap. Hoping this corrects leak. That’s what I get for cutting a corner out of pure laziness. Rolling eyes.
Old Sep 4, 2019 | 02:29 PM
Keep throwing parts at it, it's your $$$.
Now, you are you throwing used fuel injectors at it, when your vac leak is at the intake manifold?
I still have the original factory installed fuel injectors on my '07 and I don't have a check engine light!
My advice to you is to spend more time doing research (there's a ton of information on this site) and less time throwing parts at it.
Old Sep 4, 2019 | 05:02 PM
C50bart's Avatar
It was already purchased because when installing the intake the wires in the loom got pinched between the intake and head. My son and I removed it and repaired it but I didn’t think of a vacuum leak throwing the code. I figured it was the injector that was pinched got fried by grounding out. My injectors have 153k on them and the other purchased half that from a wreck. Either way the $50 gives me piece of mind because my son will be driving it and I won’t have to worry about him driving the truck.
Don’t be so pessimistic.... 🤨
Old Sep 4, 2019 | 06:11 PM
Don’t be so pessimistic.... ��
First, you need to understand that there are people all around the world viewing your posts.
Your misinformation could cause many to lose money just like you.
I have saved my customers $hundreds of thousands$ over the years, many came for a second opinion!
Btw, I will NEVER install USED parts, especially on my kids vehicles!
Just go back and check over your work and check the torque on the manifold bolts.
OBD II Fault Code
  • OBD II P0303
Fault Code Definition
  • Misfire Detected in #3 Cylinder
P0303 Symptoms
  • Check Engine Light flashing
  • Rough running, hesitation, and/or jerking when accelerating
  • In most cases, there are no adverse conditions noticed by the driver
  • In some cases, there may be performance problems, such as dying at stop signs or rough idling, hesitation, misfires or lack of power (especially during acceleration), and a decrease in fuel economy
Common Problems That Trigger Code P0303
  • Worn out spark plugs, ignition coils
  • Incorrect ignition timing
  • Vacuum leak(s)
  • Low or weak fuel pressure
  • Improperly functioning EGR system
  • Defective Mass Air Flow Sensor
  • Defective Crankshaft and/or Camshaft Sensor
  • Defective Throttle Position Sensor
  • Mechanical engine problems (i.e.—low compression, leaking head gasket(s), or valve problems:
  • https://www.hummerforums.com/forum/h...p-41653/page3/
Common Misdiagnoses
  • Fuel Injectors
  • Oxygen Sensor(s)
  • Powertrain/Drivetrain problems
Old Sep 4, 2019 | 06:54 PM
C50bart's Avatar
Thats right. There are many like me that ask questions and get answers. If people choose to spend money on a cure god bless. Tell me what I have asked with my situation that’s “misinformation”? I have told anyone what to do, I have asked what to do and in meantime I have found out the issue before anyone actually contributed. Just because I might be new on Hummer forum this isn’t my first forum rodeo. I have a Ford, Benz, and gym forum subscription. Never had anyone tell me in 20 years of asking and answering that I misinformed them or anyone. Thanks for the copy n paste.
I have the shop disk with all the 2007 info from GM. I seen all you posted in the pdf files. However, I pinched wires on the injectors so it safe to assume they could be shorted and wouldn’t be s misdiagnoses.
https://drive.google.com/drive/folde...hZRM2V4AJR9ZtD
The list of possibilities was all checked except for vac leak because from my experience you hear it as motor is running.
The o2’s are a misdiagnosis but i’m replacing because they do go bad and again I want my son having a worry free first car experience.
You call it wasting money i call it piece of mind. I replaced all the sensors and gaskets from the block up.
OBD II Fault Code
  • OBD II P0303
P0303 Symptoms
  • Vacuum leak(s)
Common Misdiagnoses
  • Fuel Injectors
  • Oxygen Sensor(s)
Old Dec 28, 2019 | 12:08 PM
edmundo528's Avatar
Can you please tell me where exactly your leak was? Maybe a pic? and how you found it?
Hummer2006h3
20
May 12, 2014 07:41 AM
BiGDoG1010
Oct 27, 2013 06:48 PM
telemike
Dec 27, 2012 06:59 PM
Runnman
Dec 8, 2010 04:19 AM
