07 h3 bad idle
Yeah, just weird issue that is kind of baffling. sometimes the stability light will stay on for miles and it runs fine.once off...it goes back to the rough running condition. Pull up to a red light with the light off,...it bobbles and idles bad. Light comes back on...idles level. weird..lol
P0108: The ECM detects that the MAP sensor voltage is more than 4.90 volts for more than 4 seconds.
Vacuum Leak will cause high Map sensor voltage, reduced power, stabilitrak disabled.
FIX THE VACUUM LEAK AND RECHECK.
Also, make sure your scanner has the ability to pull codes from ALL modules!
Btw, there are many other issues that could cause stabilitrak to disable.
There's a tsb on the the map sensor wiring to connector, which could cause P0107 (The ECM detects that the MAP sensor voltage is less than 0.10 volt for more than 4 seconds).
Watch and Learn from this partsthrower=$$$$ for an example of a simple cheap repair:
Checking ground points (pulling them off, cleaning them up, and re-securing) might be a solid cheap and area to put on the to-do list. Another would be inspecting wires on and around the engine as well as popping off the cover of the plastic harness cover mounted to the valve cover (near the timing chain) to inspect for exposed wires in there (I have been told some people have had issues in there). The worst case, you know you have solid ground connections and no exposed wires. Best case, it resolves an issue or two.
Charles Coutts
Jan 21, 2016 08:20 AM
Justinh
Jan 9, 2016 11:18 AM
