06 hummer h 3 overheating and no heat. I've replaced the water pump, radiator and the
Old Nov 3, 2022 | 06:32 AM
Engrfer's Avatar
Default 06 hummer h 3 overheating and no heat. I've replaced the water pump, radiator and the
06 hummer H3 overheating. I've replaced the water pump, radiator and thermostat. the top hose is hot hot but the bottom hose is cold and seems no coolant. Please help. Thank you.
Old Nov 3, 2022 | 07:13 AM
Mammoth H3's Avatar
Did you have this problem before replacing the parts? If not make sure the thermostat is not backwards.
Old Nov 3, 2022 | 11:25 AM
Bad Tstat (I've seen brand new Tstats that won't open) is the only thing it could be if the upper radiator hose is hot and the lower is not.
Old Nov 3, 2022 | 01:10 PM
why the big azzed bold print?
billygsims
Aug 10, 2021 10:38 AM
KellyFaith
Jan 8, 2021 09:39 AM
RFlagg813
Apr 9, 2017 09:44 PM
bblue1099
Mar 9, 2014 09:59 PM
brians08h3
Jul 1, 2012 11:04 AM
