06 H3 Door alarm sensors... Which ones?
Old Oct 19, 2024 | 05:44 AM
wpage's Avatar
Question 06 H3 Door alarm sensors... Which ones?
Question for the H3 Guru's here. So it seems one or more of my door sensors has failed.
How can I test to isolate which one to change out?
THANK YOU
Old Oct 19, 2024 | 09:50 AM
Happy Hummer's Avatar
Hey Woody,
I use a paper clip as a jumper. Just leave door open carefully remove switch and don't let wires fall inside. Once jumpered lights inside should go out.
Toss the switch on a DVM set to ohms and verify you're getting a proper connection internally. Closed low resistance. Open high resistance. Use contact cleaner on each switch and retest if necessary.
Old Oct 19, 2024 | 03:34 PM
wpage's Avatar
Hey Woody,
Thanks for that Happy Hummer. So you indicate it may be dirty contacts. I ordered 2 replacements from amazon...
So meantime. Will do some continuity testing and see what can be found. Maybe one of my switches is just fouled.
Do appreciate your reply.
Old Oct 21, 2024 | 04:02 AM
wpage's Avatar
Problem solved. The tail gate door switch had corrosion on the contacts.
CRC QD spray and some q tips and tooth pics to the rescue.
Each switch had some carbon. Only one switch had enough to cause the "open circuit" that caused the false door alarms to the DIC and totally crazy audible and lock operation conditions.
Old Oct 22, 2024 | 06:29 PM
Justinh's Avatar
Thanks for the follow-up.
Old Nov 3, 2024 | 04:03 AM
wpage's Avatar
Smile
Welcome buddy...
Glad I got the 2 replacements from amazon for about $16.
The tailgate switch failed after my last trip surf fishing. (Salt water corrosion) So I replaced that one for the win.
Old Nov 3, 2024 | 03:36 PM
wpage's Avatar
May have led to a trouble,,,
dkb123
Jun 21, 2022 12:24 PM
Humvee21
Apr 10, 2015 03:28 PM
parrip
Apr 18, 2014 02:24 PM
spector
Dec 30, 2012 11:32 AM
redprowler
Jun 4, 2006 03:41 PM
