Squeaky Driver Door ...
Old Dec 28, 2017 | 10:41 AM
dkb123's Avatar
Default Squeaky Driver Door ...
Anyone experienced a really squeaky door?
I have lubed it everywhere I can think and it doesn't seem to help. Mine is the Drivers' door which obviously has seen the most use.
In case anyone has the solution for this one ...
Thanks!
Old Dec 29, 2017 | 02:02 PM
mcioci's Avatar
Thanks!
I have same squeak when I open door only. going to grease the hinges and see if that helps.
Old Dec 30, 2017 | 11:14 AM
LoJac963's Avatar
If the squeak is when opening/closing then it is most likely the door check. I replaced all 4 of mine when I changed my door speakers and the squeaking is finally gone. I had not only a squeak but a POP on the driver door and couldn't take it anymore. They are around $30-40 each and you must pull the door panel off to access it.
Old Jun 21, 2022 | 11:06 AM
C57's Avatar
C57
Default Squeaky door
Hey LoJack, where can you buy the door pieces. I heard a piece of metal fall from it and now the door won't stay open all the way. Like it broke off the tip or something. Halfway still works tho.
Old Jun 21, 2022 | 12:13 PM
Old Jun 21, 2022 | 12:24 PM
C57's Avatar
C57
Default Huh.
Nothing comes up but a search box!
Shiftrus
Sep 19, 2019 07:47 AM
Shiftrus
Sep 17, 2019 05:50 PM
Humvee21
Apr 10, 2015 03:28 PM
slider28
Sep 27, 2014 05:11 AM
IYF_H3
Mar 7, 2007 01:35 AM
