Squeaky Driver Door ...
Anyone experienced a really squeaky door?
I have lubed it everywhere I can think and it doesn't seem to help. Mine is the Drivers' door which obviously has seen the most use.
In case anyone has the solution for this one ...
Thanks!
Thanks!
I have same squeak when I open door only. going to grease the hinges and see if that helps.
If the squeak is when opening/closing then it is most likely the door check. I replaced all 4 of mine when I changed my door speakers and the squeaking is finally gone. I had not only a squeak but a POP on the driver door and couldn't take it anymore. They are around $30-40 each and you must pull the door panel off to access it.
