*&^%$ vacuum line clips
Old Jan 26, 2020 | 12:38 PM
bureau13's Avatar
Default *&^%$ vacuum line clips
OK, so I'm trying to follow the instructions here: https://www.hummerforums.com/forum/h...acement-28763/
Pretty straightforward procedure with photos on how to replace the purge solenoid. Unfortunately, and possibly because I'm an idiot, I can't get the vacuum line clip off...the one opposite the electrical connector, towards the front of the truck. The other side I've seen before...U-shaped piece of plastic, just slide it back and pop of those hose. This one is different, and I'm sure it's easy, but it's not that easy to see in there, even with everything else disconnected. Someone give me a hint before I lose it and take the snips to that line.
Old Jan 26, 2020 | 12:53 PM
from what I saw on here at around 1:35
they both (rear and front lines) have a tab you lift then it releases.
the video is pretty horrible but you can kinda see him release it.
Old Jan 26, 2020 | 01:02 PM
bureau13's Avatar
Interesting vid, thanks. Looks like he had to mess with it a bit too. Looks like he was doing what I thought I was doing, so I will keep prying at it I guess.
I miss the regular old metal clamps. This "fancy" stuff irritates me.
Old Jan 26, 2020 | 01:32 PM
bureau13's Avatar
So, true story: I went back outside after typing that reply and the hose literally fell off the solenoid when I touched it. So I guess what I was doing was correct
TechnoSean
Dec 18, 2019 08:54 AM
Robrote
Nov 26, 2015 08:07 AM
drmeek
Jan 19, 2014 05:54 PM
Chad
Sep 10, 2011 06:20 PM
rwdr
Feb 16, 2011 09:29 AM
