Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
Remote Control Door Lock Receiver Location?
Old Jul 10, 2020 | 09:53 AM
Mule's Avatar
Default Remote Control Door Lock Receiver Location?
2009 H2 SUT
Remotes started to only work if held inches from vehicle. Previously they worked great. Changed batteries in remotes. No joy. Checked battery voltage, All good.
Chasing the RCDLR as culprit. No clue where it is located. I see some reference the BCM, but found a separate part number for the RCDLR.
Any suggestions appreciated.
Old Jul 10, 2020 | 11:12 AM
legerwn's Avatar
right above the IPC in the dash,
the dash cover has to be removed along with the defrost nozzle on the driver side
this is for the 08 so I'm guessing its the same for the 09
Neal
Old Jul 10, 2020 | 11:14 AM
legerwn's Avatar
It has an antenna that is attached to the A-pillar to the left of the steering wheel
Neal
Old Jul 10, 2020 | 11:33 AM
legerwn's Avatar
also the Tire pressure system uses the same FM receiver and antenna (located in the RCDLR), are you having issues with the TPM system?
The RCDLR receives a signal form the remote transmitter to start it sends a signal to the BCM and then the signal is sent to the ECM, both check for a list of conditions to be met then the start command is allowed.
Neal
Old Jul 10, 2020 | 12:04 PM
Eagle's Avatar
Check remote. Open up and clean button contacts.
Old Jul 13, 2020 | 07:55 AM
Mule's Avatar
Thanks for responses. Remotes all good, cleaned up w/ new batteries-still have issue. TPM has a occasional issue with signal (1 day out of month), then it's fine. With lock/unlock, remote start, and TPM issues, kinda looking like something with the RCDLR. Thanks for the input, I'll go to digging.
Spike44
Oct 18, 2020 05:57 PM
LGunner
Apr 24, 2014 08:43 AM
happythree
Feb 14, 2014 02:49 PM
SMLNBAD
Jul 7, 2009 06:08 PM
Chameleon
Jul 4, 2009 07:09 PM
