Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
H2 SUT 08 Bose amp question
Old Jan 14, 2024 | 08:21 PM
H2-SUT's Avatar
Default H2 SUT 08 Bose amp question
I have noticed an interesting problem, my factory BOSE amp seems to just shut of from time to time. If I shut the vehicle off and restart it bingo sound is back. Can't get to happen by changing any setting on the radio.
The amp tests fine with the Tech2. So here's the question, Does the BOSE amp get turned on by the BCM or does it sense input from the radio and turn on, or something else?
Old Jan 14, 2024 | 10:13 PM
if you have a radio interface module they can do that some brands more then others. read the reviews .
Old Jan 15, 2024 | 07:09 PM
H2-SUT's Avatar
Actually I am trying to figure out how the BOSE amp turns on with a stock setup, not aftermarket.
Old Jan 15, 2024 | 07:37 PM
The amp/speaker receives a signal from the radio+needs 12v power/ground to relay the signal, all other speakers work without 12v power. Poor connections to the amp cause overheating protective mode shutdown to prevent failure.
Old Jan 15, 2024 | 07:42 PM
H2-SUT's Avatar
Thx HummerZ, I need to see if I can find a schematic that shows what that lead is and find out if I have a bad connection or amp going bad.
hmer
Sep 16, 2018 02:48 AM
bad70ss454
Feb 26, 2014 04:01 AM
cecil-1
Nov 21, 2010 07:30 AM
Mad Professor
Apr 18, 2009 06:49 AM
miller529
Apr 15, 2009 08:57 PM
