H2 2003 Unknown driver
Mine was a bad BCM, if you go with a used one, make sure you match the VIN, and I would only pay $150 for it. If you want to go with new like I did,,, replace it,, go through the security bypass programming and then take it to a dealer to finish programming. I will add two links, one for the part, for $170 new OEM and the other for the security video.
2003 HUMMER H2 Parts - GM Parts Direct
Hope this helps
Hope this helps
Did you find out the unknown driver issue with windows not working and all the other
Hello everybody!!!
Before few days, my h2 stoped working. On display is "Unknown driver", and it can not start engine, actually it start on a second and then turn off, (like immobilizer).
Central locking, el.windows, gauges, radio....does not working too!!
Unfortunately, i have only one key without remote.
I searched forum and i find similar post, but I didn't find right answer.
Can someone help me???
Thanks in advance!!
Thanks in advance!!
myveryfastgt
27
11-04-2015 04:24 PM
HummerH2
10-08-2007 02:31 PM
