Back up camera advice
Visibility is a real problem backing with my H2 SUT on 22" rims. I know nothing about back up cameras, but having one would be a great help. Is there a back up camera made for Hummers that will adapt to the factory in-dash Hummer monitor? Any suggestions or recommendations would be much appreciated.
It would be cheaper to buy a new head unit as the back up camera interfaces to use the factory screen are just as expensive as a cheaper head unit with this feature already included.
Or you could go the route I went and add a small screen with a backup camera. All you need is 12 volt power and grounds and running the included wires and you are good to go. Check the last page of my build thread for some pics if you'd like.
I've been doing some more research on this and it appears what I need is a "plug and play video interface" and a back up camera for my Hummer. Waaaaay cheaper than footing the bill for the Pioneer (thanks much woodwardsh3). The folks at Crutchfield were super helpful with much great advice (HIGHLY recommended). My in-dash Nav, radio, and screen work just fine, so I don't see any reason to replace the whole unit. I have found several on line, so it looks like I got it figured out. Thanks to everyone who were so kind to assist me.
So which module was it? I have priced all the popular modules are they are at least $250 and much more.
So it transmits to the FM radio band like an FM modulator? I'm curious how they explained it to you because without a much more expensive module there is not much that can directly plug and play into the factory nav.
I figured the same thing. I freely admit I know little to nothing about electronics, so basically I was at their mercy when they explained it to me. I asked them directly; Will this interface with my existing NAV/radio monitor and require nothing else? They said yes it would, as a Hummer H2 was what it was specifically designed for. The description says it transmits up to 45 ft connect to a constant power source. Reading the installation instructions, it sound pretty simple and straightforward. FWIW the reviews rated it very high. I would suggest you go to the link I provided and check it out for yourself.
I did look at it. I had contacted them a while back as well inquiring about backup cameras but they sent me to a different universal module. I can't remember which one it was but needless to say it was still expensive and I decided to go a different route which was much cheaper.
Aggiedad04
06-07-2018 03:28 PM
TexasNative83
12-17-2011 05:56 PM
tlzkaasen
11-18-2010 04:24 AM
foozed
07-29-2008 02:28 PM
Greenblade
10-20-2006 09:38 PM
