Winch for H2
Old Sep 1, 2023 | 07:18 PM
Normwolfe's Avatar
Default Winch for H2
What winch is recommend for the H2 mounted on a receiver hitch mount
Old Sep 2, 2023 | 09:00 PM
XLRH2's Avatar
I have the warn winch complete bumper/hidden mount, after over 20years now (EEEK!), still functions great.
Old Sep 2, 2023 | 09:52 PM
Normwolfe's Avatar
Default Win h fie H2
So the least expensive way would be the Badlands XZXR 12000 m. Cost approx. $350. Receiver hitch $75.00 attach to front receiver. The only Warn winch’s that can be mounted in the warm receiver hitch are the 104 series Warn’s. The two winch’s are approx. $1500 each and the receiver mount plate approx $500. I will go with the Badlands winch
Old Sep 6, 2023 | 12:08 PM
Gavin Costigan's Avatar
What you’re doing is exactly what I did. I used a badlands winch with the badlands hitch adapter.
A few things to note:
- you have to drill a hole vertically in the hitch adapter for a vertical pin. The front receiver on the h2 uses a vertical pin as apposed to the horizontal on on the rear and the adapter mount.
-the front receiver is only rated for 9k lbs so I went with the 9500lb badlands winch to match what was included in the warren kit. It has been more than plenty in my experience l. If you need more power you can always ****** block it.
-make sure you have a battery cutoff for the winch as it draws power when not in use. I also used a set of Anderson connectors to make removing the winch easier.
H3Ray
Feb 27, 2015 01:30 PM
franzu666
Apr 20, 2014 12:43 AM
Caraddict
Jun 5, 2011 05:39 PM
RickLF
Dec 19, 2007 07:54 AM
RickLF
Apr 20, 2007 12:45 AM
