Winch problem to fit H2
Old Dec 18, 2007 | 08:39 PM
RickLF's Avatar
Default Winch problem to fit H2
Hi Everyone.......
I am wanting to install the Warn Winch 12,000 lbs model, w/air comp. using the front Hitch port.........
warn does have the complete front bumper mount for a 9,000 lb winch, but it would not be portable or the winch, I would like to have on the front of the H2
Warn seems not to have the mount for it,nor does Super winchs poratable mount.....that i can find.......
In order to use the portable Hitch, the Tube has to have two holes, one Vertical for the Front and a Horazontal for the rear, in order to be portable from either side to use........
Does anyone know of a Hitch plate I can use for this H2 applacation???
and where to buy it at..........
Question #2
The Warn winch im looking at is the 12,000 lb winch with 80 ft of 3/8 cable........
Theres also the 9,500 lb pull with 120 ft of 5/16 wire cable....
is bigger better..........or just over kill??
Both have the air compresser on it................and same price.........
Whats your Opinon........
I want to use it for Mud and Sand.........and those not to often, trees that fall down after a Hurrcane blocking my Exit..........
Thank you in advance...........RickLF
Old Dec 19, 2007 | 01:34 AM
shortbus's Avatar
Default RE: Winch problem to fit H2
just buy the standard warn setup and drill another hole for the other mount. i did that, with the second hole offset about 3/4" from the other one.
Old Dec 19, 2007 | 07:54 AM
djguy988's Avatar
zactly
helium3
May 11, 2013 02:01 AM
Mustanggirl666
Nov 26, 2012 07:15 PM
TerpGuy
Aug 21, 2010 10:41 PM
parishh3guy
Jul 31, 2007 05:39 AM
CruisinCarAudio
Apr 3, 2006 03:07 AM
