What's Your Best Youtube 2008-09 Mirror Glass Removal Video
So we covered this alot on this board. I'm getting close to removing my Passenger side mirror glass to in stall new motors. I have been looking for the best way to do this without cracking the original gass as it's coated for High Beams. I did by a regalement Mirror for the passenger side and it is heated just in case I break the original, but it's not coated and I think it is not shaped for the passenger side as the factory ones have a Left and right bend shape in them
This guy in the Video uses a 9/16th in wrench to pop the mirror lose using the boxed end. Seems like a Good way to pop it lose without breaking it. He is doing it on a 2005 model. Have you found a safer way or a better way of doing this? Have a Video you can link here. Thanks...Here's mine. Thanks
Mark R
Mark R
Yeah I'm sure It Does Pop Right Out.... But I don't Jump Out Of Perfectly Good Airplanes either as I'm a "LEG" Only you and I know what that means. I Know I'll use a Pair of Jump Boots and bash the rear to make it Pop Out.
is that a 63 split window? I have a 13 GS cammed, supercharged, tuned Vette.
Sorry about hijacking the thread. I have seen plenty of good videos.
I think this is the entire mirror replacement?
https://youtu.be/Og-HleD6TNg?si=hdpuPv5I2NUs1aA8
You were a "LEG" in Vietnam. I don't care if you were an officer or NCO, I salute You.
Nah Creepy.. It's a 65 with a BB 502 and MSD EFI and a Tremec 5 speed. Yor GS with a Huffer is cool.... Also had an 86 With a Vortec SC and Doug Nash Stock 4+3 Tranny. Thanks For the Salute... I was Combat Engineers 66-67 VN . Pulled the 11 Bravos out of deep do do they always managed to get into. Got F-up and am Disabled Also 100%.
I'll check out your Video and the other one posted here. Thanks Airborne.
Edit: Yeah I saw that one. Thats a replacement of the complete mirror arm. I just want to change out the Tilt Pan Motor in the head. All I have to do is pop the Mirror Glass out with out F-ing it up so I can change the pan tilt motor behind the Mirror..
PeterM
Aug 7, 2011 06:55 PM
